Cleaning K&N filters
Old Jan 9, 2001 | 09:59 AM
fbodfreek's Avatar
Car: 1990 Camaro Iroc-Z Convertible
Transmission: Automatic
I just bought a Iroc-Z convertible and it is equipped with k&n's. Unfortuately, after traveling through OK bringing it home in a bad snowstorm, they got clogged with salt, sand, and just some plain bad stuff. How do I go about cleaning them. I know there are the K&N oils, but do those come with instructions? If someone could tell me how to go about cleaning them or lead me to a Tech Article, I'd sure appriciate it.
Old Jan 9, 2001 | 10:37 AM
911LE's Avatar
Don't have the K & N supplies in front of me so this is from memory. You should use air filter cleaner and air filter oil (K & N makes some, so does AMSOIL, I assume a few others do as well). Liberally spray the cleaner, wait 10 minutes and then wash with water in the REVERSE direction of the air flow. After the filter dries completely coat liberally with the air filter oil. The cleaner and oil will have directions on them. Summit, Jegs, etc. sells small cans or larger cans. I would assume some local parts and/or performance stores would carry them.
91 1LE
305 LB9 5-Speed, Dana-44
AutoPower 6-pt Cage, Koni adjustables, Polyurethane bushings, MSD6AL, Crane coil, TPS Airfoil, K&N filters, Fastchip, Taylor Pro 409 wires, Grant, Airquip, Performance Friction, Jazz, Autometer, Centerlines, 10LB Halon
Old Jan 9, 2001 | 02:30 PM
fbodfreek's Avatar
Many thanks!!
Old Jan 9, 2001 | 05:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, get the K&N filter cleaning kit. Its about $10 and should be right next to the K&N filters in your auto parts store. Directions are in the box.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
edoff13
Sep 11, 2015 03:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
