Car shutters bad!!!! Need help!
Old Dec 21, 2003 | 11:56 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Ok today I started my car and it ideals fine I let it warm up a bit and I am off while accelerating my car shutters violently I mean rattles the windows violently! After it shuttered I let go of the gas and eased on it again and as long as it’s below 1500rpm it does not shutter I tried flooring it once and the car died! Flat out I started her back and it was still shuttering once temps reached about 160 the car was fine ran like it always has.. After it sat for a while I started it again same problem! I have checked all the plug wires cause I installed new headers about 3weeks ago non are even close to the tubes and none is burnt what’s up!?!!??
Old Dec 22, 2003 | 05:25 AM
ede's Avatar
ede
scan it for codes, make sure the tune up is good, filters clear,make sure the wires are on in the correct order. might want to look at the iac or cts.
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Apr 9, 2016 10:20 PM
B_Dubya
Aug 26, 2015 05:09 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
