Questions on 91 Camaro RS
Old Jan 9, 2001 | 02:00 PM
Spacehampster's Avatar
I have just recently bought a 1991 Camaro RS with a 305 motor. Does anyone know about what the original hp was for this motor? Also, does anyone know where I can find weatherstripping or any of the rubber for the t-tops? All the dealers have told me that they don't carry nor will they order the item. (Its the piece right above the driver side window, about an 1 1/2 wide and the length of the window long.
Thanks!
Old Jan 9, 2001 | 02:02 PM
CamaroSpawn's Avatar
185hp I believe
Old Jan 9, 2001 | 02:09 PM
Thaks for the reply, its been killing me that I didn't have a clue!
Thanks again
Old Jan 9, 2001 | 02:52 PM
daniel91rs's Avatar
Glad to see you made it from camaros.net, you'll see how much better this site is
91RS 305-k&n,flowmaster, ASCD S.S. hood,March Pulleys
Old Jan 9, 2001 | 03:26 PM
badbird88's Avatar
Try 170hp and about 255 on torque.
The weather stripping can be found in the following magazine but it isn't cheap! They have some excellent selection of almost any part you need for our 3rd gen cars and 4th gen except a few discontinued parts but they are working on those.
http://www.yearone.com/nextgenparts/...ages/main.html
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Old Jan 9, 2001 | 05:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
All thirdgen 305 TBI engines are 170 HP and 255 torque.
Soft Seal makes weatherstripping for our cars, along with other companies I cant think of right now.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited January 09, 2001).]
Old Jan 9, 2001 | 10:34 PM
Adam89F's Avatar
I don't think you can generalize and say "all 3rd gen. 305 are 170hp and 255 torque."
But for the 1991, you can.
West Coast Performance
1989 Formula 305 TBI
Old Jan 10, 2001 | 01:01 AM
Pat Hall's Avatar
Actually Adam, Kevin is right. They were all rated at 170 HP from the factory. Unless you modify something, that's what they're supposed to produce. I'm pretty sure they used the same camshaft on all TBI cars from 88-92.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Jan 10, 2001 | 01:29 AM
Adam89F's Avatar
Ahhhh haaaa.
88-92
What about 85-87 models?
Just kinding around.
Old Jan 10, 2001 | 01:01 PM
Kevin91Z's Avatar
I didnt say "all thirdgen 305's", I said "all thirdgen 305 TBI's". There's a difference. All stock TBI engines in all thirdgens, whether its a base model, IROC, Trans Am, etc, are rated at 170 HP and 255 TQ, from 88-92.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
