What how do you prevent rust from eating through your paint?
Old Jan 10, 2001 | 01:19 PM
crazeinc's Avatar
I tried my best sanding down the rust on my S-10 before covering it with rustoleum, but this winter here in Chicago has been brutal and the rust on the bottom of the doors is just making the paint flake off...what do I do??
Thanks.
1982 Camaro Z28
trying to make it worthwhile for the spring....
Check the website for progress http://members.fbody.com/Pro82Z/
Old Jan 10, 2001 | 01:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
http://www.por-15.com
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 10, 2001 | 01:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's coming from underneath, about the only thing you can do is treat the back side somehow... POR-15 works well for that but you have to get it applied to the source, which sometimes means disassembly of the vehicle; replace the metal; make sure the drain holes are clear; rinse the car with known non-salt water.
Smearing more Bondo over it and squirting another coat of paint on it won't cure it.
Old Jan 10, 2001 | 05:00 PM
theformula's Avatar
try autobodystore.com
Click on "bulletin board" when you're there. A LOT of experienced body guys who can help you with this one.
91 Formula
305 TPI 5speed
1LE/G92/WS6
K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(47psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires,Bosch O2sensor, SLP headers & catback,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads.
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
