My rear end in screwy
Old Jan 9, 2001 | 10:34 AM
CamaroX84's Avatar
I have a completely stock 84 Sport Coupe with the 3.08 rear end. I thought almost for sure it was an open rear end. When I went to the drag strip, I had rubber from the track only on my right rear quarter panel. Well, my friend was backing my car out of the garage, and there was still some sno on my driveway. I saw the left wheel spinning when it hit the snow. Could this be a limited slip differential? Why would it only spin on the right at the strip, and the left in my driveway? (although I didn't see the right side at that time, so it COULD have been spinning as well) Or could it just be a broken posi? Any help would be much appreciated. Thanks.
1984 Camaro Sport Coupe - 73K Miles
5.0 Carbed LG4
COMPLETELY stock except for a K&N Air Filter
F41 Suspension Package
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Complete 3" Exhaust System
Aluminum Drive Shaft
3.27 Disc Brake Posi Rear
Old Jan 9, 2001 | 01:46 PM
The Rusty Trombone's Avatar
yeah im pretty sure thats limited slip... i have a ****ty limited slip rear and i do burnouts in drive to spin the right tire and then in reverse to even out the tread wear =)
1987 Midnight Blue Camaro IROC-Z, 350 TPI out of an '88, Accel 8.8 wires, hypertech air foil, flowmaster american thunder 3" dual outlet cat-back... slipping tranny!! (T5 swap next spring!!)
Old Jan 9, 2001 | 02:14 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Won't an open diff spin the right rear going forward, and the left rear going backward? That's how my old 3.42/open/drum axle worked...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 9, 2001 | 11:55 PM
crazygearhead's Avatar
open differentials can lock up and spin both tires. i know this for a fact because my friend has one and has spun them both left 2 tire marks in front of my house. (it also caused him to fishtail quite nicely) my guess is that it is an open diff. or possably a broken limited slip..
If it breaks, it wasn't good enough anyway.
Old Jan 10, 2001 | 10:18 PM
crazeinc's Avatar
it has a 99% probablity of being an open rearend...
before I got my new rearend with posi I was able to get my open rearend to burn both tires twice. Both situations were when traction was serverly limited (fishtail and slick road) or for you, snow. I thought the same thing as you and found out it was an open diff.
Just jack up the car and spin the tire and if the other one spins then you have posi, if not, then you know...
1982 Camaro Z28
trying to make it worthwhile for the spring....
Check the website for progress http://members.fbody.com/Pro82Z/
Old Jan 11, 2001 | 01:24 AM
Bort62's Avatar
its an open Diff.
Mine will spin Both tires in reverse 70% of the time, and both In forward ( ha ) 10% of the time. if its rainy or gravel or any other limited traction it will spin em both every time.
and Ive got no Dillusions of Posi, Its a one wheel wodner baby.
Oh yeah, 85 SC with 3.08's just like you
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
