Fuel pressure regulator questions
Old Jan 10, 2001 | 11:55 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I have an 89 GTA with the L98. What kind of gains, if any, can I expect to see from an adjustable fuel pressure regulator. Particularly the quarter mile is what I'm talking about. Will it kill my gas mileage? Im getting about 10 mpg right now driving easy. What are the reccomended pressures for best performance? I ran 14.85 stock
1989 GTA, L98/auto, t-tops, Black w/ grey int.
Ran a 14.85 @ 93.4 mph BONE STOCK
Old Jan 11, 2001 | 03:02 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Wow 10 is not good at all. Do you know what your fuel pressure is right now? Is should be around 43-48 or so on a stock engine. This is with the fpr disconnected I believe. It might actually improve your mileage since increasing the pressure will give you slightly better fuel atomization coming out of the injector. Pressure doesn't determine the actual flow the computer does. Above all though, the afpr is mostly a tuning aid to help tune the car in light of other mods, and not really a hi powered mod in itself. TPIS claims that some cars came with stock pressure near the top end of the range eg 47 or 48 psi, and these were the "quick" factory cars, and some came with lower (43 or 44) pressure and they were slower. So theoretically if your car is low to begin with an afpr can put the car where it should be and result in a good improvement. Don't buy one, read Vader's article on how to make one. It's in the tech section I believe or I could email it to you so he doesn't have to post it yet again...lol. Later
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
[This message has been edited by I ROCK (edited January 11, 2001).]
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
