TES Headers Interfering With Oil Cooler?
Old Dec 27, 2003 | 07:30 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
We've been putting edelbrock TES headers on an 88 formula 350 today, we got the d-side header in, but it looks like the oil cooler is going to be in the way with the y-pipe, or the lines will be touching the collector. Anyone have the TES headers with an oil cooler?? If so, did you have any problems and what do you suggest doing to fix it?
Old Dec 27, 2003 | 07:44 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
My brothers 92 has TES headers and a oil cooler no problem at all. Take a picture of your problem and maybe i can help
Old Dec 27, 2003 | 11:18 PM
holov1's Avatar
Car: 89 formula 350
Engine: L98(350)
I recently done the same thing on my 89 formula 350 . the oil cooler lines are close to the header but are not touching about 1/4 to 1/2 inch. away might try moving the flange so it's not so close . doe your car have the dual cat setup? mine did. had to remake the y-pipe with the supplied pipes(edelbrock kit) but worked out o.k.
Old Dec 28, 2003 | 09:45 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I have the TES with oil cooler the lines come really close to touching it but no problems yet they've been on the car for 3 or 4 years now. I was planning on replacing the hose with a new one with heat wrap but the OEM hasn't even started to get soft yet.
Old Dec 28, 2003 | 10:31 AM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
I just installed Hooker 2210s and just removed it completely. I can't imagine that the oil cooler is doing much, considering it just runs (hot) coolant around the filter flange. Added bonus is you can run a longer filter if its gone.(WIX-51061) Just run a cooler thermostat and a cooler fan switch and you shouldn't need it. Just more uneaded weight to carry around.
JMO,
Charlie
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
carattini
Sep 10, 2015 07:46 AM
Jlanz55
Sep 6, 2015 07:28 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
