Spun bearing noise
Old Jan 10, 2001 | 11:55 PM
Ratnose86SC's Avatar
Spun bearing noise
Would i notice right away if i spun a bearing. As im driveability and performance?
My car makes a god awful knocking sound and i didnt have the time to find track it down myself, so i took it to the dealer, and i hope its something stupid.
The only problem was the damn noise. Nothing else changed. Timing chain?
Old Jan 11, 2001 | 06:08 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
A spun bearing makes a loud knocking noise, and when it siezes to the crank, it makes a really horrendus squealing noise as the bearing spins inside of the cap/journal. If the bearing is just shot, you can usually just put bearings or crank kit in. If the bearing has actually "spun", then usually its time for a short block.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 11, 2001 | 09:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Cracked flex plates make a horrendous knocking sound but affect little else (at least until they break clean in two!) If you have a spun bearing, you will almost always see a radical drop in oil pressure due to the massive internal leak from the pressurized system that the bearing clearance will create. If your oil pressure hasn't changed, and I mean not at all, then your bottom end is OK and the problem lies elsewhere.
mrbird
Oct 20, 2015 03:43 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
gord327
Oct 3, 2015 01:25 PM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
