smog removal....another question....
Old Dec 28, 2003 | 09:08 PM
MurCurY's Avatar
Car: 86 Camaro Berlinetta
I have an 86 Camaro Berlinetta w/ 305 and 4 Barrel Carb. How do I remove the emissions control stuff? Smog pump and whatnot? I read the "serpintine driven" one....but mine doesn't have a serpintine....it has multiple belts. Is there a faq on this somewhere?
Old Dec 28, 2003 | 09:58 PM
ckeene502's Avatar
all i did was remove all of the hoses first, then take off pump, removed a.i.r. tubes from manifold(try to soak them with lube overnight) using a line wrench, it also helps to have a stuby wrench.
keene
jaridjohn
Oct 5, 2015 07:01 AM
wstephan96
Sep 25, 2015 04:28 PM
