92 Rs Wont Start
Old Dec 29, 2003 | 12:25 AM
Camaroman92rs's Avatar
92 Rs Wont Start
ok i CAN TURN THE KEY AND ALL i GET IS A CLICK FROM A CIRCUIT BREAKER UNDER THE DASH.iTS A BREAKER THAT JUST HANGS OFF A BUNDLE OF WIRES ABOUT 4 INCHES FROM THE FUSE BOX.ITS BETWEEN THE FUSE BOX AND WHERE THE WIRES GO THRU THE FIREWALL.ALL MY DASH LIGHTS COME ON AND EVERYTHING ELSE IS NORMAL.WHATS THE CIRCUIT BREAKER GO TO.ANY HELP WOULD BE APPRECIATED.THX.
Old Dec 29, 2003 | 02:35 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
I have this problem sporadically with my '92 RS. But it always starts after 6 or 7 tries. I believe it is either starter related or VATS related.
Old Dec 29, 2003 | 04:39 AM
ede's Avatar
ede
turn off the cap locks. more than likely it's a relay not a breaker. check for power to the starter and check the battery for a charge.
Old Dec 29, 2003 | 12:09 PM
deb92rs's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Also check your connections. Those are common culprits.
If your fuel pump gets primed, then your VATS should be okay. The VATS activates the ECM and the ECM enables your fuel pump relay. According to the HELMS manual if the security light on your panel lights up when you turn your key and stays on, and the car fails to start then you have a problem with the VATS. If the security light only stays on for a couple of seconds then the VATS is functioning correctly.
Else, like ede said.. battery, starter or solenoid
I'd have to look up what you're referring to as a circuit breaker. Are you the originial owner of the car? I don't recall seeing this on mine. Could it be something else like a kill switch?
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
