code 35
Old Dec 30, 2003 | 09:04 AM
squirrelybird's Avatar
code 35
my car threw SES last night, first time it's ever thrown a code. pulled it this morning, code 35. my paper says 35 is an IAC fault. i've replaced my IAC before, and i just pulled and cleaned some carbon or wqhatever off it, and it looks like new (i know, that doesnt mean anything) but i was just wondering if a code 35 could mean anything else? or is there a way to test the IAC before i go blow another 20-30bucks?
Old Dec 30, 2003 | 07:50 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
According to https://www.thirdgen.org/newdesign/faq/thirdgen.shtml code 35 is an "Idle speed can not be set to desired RPM". Is your engine idling higher then normal, may be a vacuum leak.
Old Dec 30, 2003 | 08:02 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
if you think you solved your problem then you should disconnect the ECM power source for 5 minutes to let the stored codes get cleared. Otherwise they will still remain, even if fixxed.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
