wild idle
Old Dec 30, 2003 | 10:48 AM
Greygoat's Avatar
wild idle
ok guys, its been a while since i posted so here it goes. My 89 tpi firebird has a tendency to have high rpms about 1000 to 1500 and wont drop. lately it has stalling out at start up. I have to press the gas for it to stay on. I have no idea whats wrong with it. Sometimes it struggles to stay on and then dies. Any ideas???
Old Dec 30, 2003 | 10:57 AM
The gta master's Avatar
Car: Pontiac Transam Gta
Engine: L98 350
Transmission: Th700r4
maybe the idle soleniod needs cleaning or is faulty...
Try cleaning it or checking all conections relating to the idle soleniod...
Old Dec 30, 2003 | 10:58 AM
Steve89GTA's Avatar
Probably a Vac leak. Check the IAC as per the instructions on this site.
Old Dec 31, 2003 | 12:45 PM
Greygoat's Avatar
I did clean the IAC and even changed out one time but returned the New IAC because it made the problem worse. What other sensor could it be that can cause the problem. What I notice is that in warm tempatures the idle goes up to 1000 to 2000 rpms and in cool weather it ranges from 600 to 1000 and sometimes it stalls out.
Old Dec 31, 2003 | 01:07 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
could be coolant temp sensor.
Old Jan 5, 2004 | 11:45 AM
Greygoat's Avatar
I have changed the temp sensor already, but the funny thing is that the other day my check engine light turned off while I put 87 octane gas could it be the sparkplugs that could be setting off the idle to go crazy?
Old Jan 5, 2004 | 05:27 PM
Vader's Avatar
Still fighting that idle problem?
Your Check Engine light turned OFF? Since I'm presuming it was ON, you should have a stored error code. What is it?
Old Jan 5, 2004 | 07:25 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
My 89 IROC had a similar problem with the idle while cold. It turned out to be a vac leak from the HVAC line. It's a hard plastic tube that gets brittle over time and cracks. There is one line from the intake to the heater control and one coming back to the heater control valve.
Old Jan 6, 2004 | 01:11 PM
Greygoat's Avatar
yes, im still fighting my problem, I will check the codes and post them as soon i can. As for the Check engine light, for some weird reason its off then while i drive it, it turns back on.
Old Jan 12, 2004 | 11:46 AM
Greygoat's Avatar
Ok, checked the codes and it gave me a 21, 32, 34, 36, and 45 does anyone know what is causing the problem????
Old Jan 12, 2004 | 01:50 PM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
21: TPS high
32: EGR
34: MAP low
45: O2 rich
I dunno what code 36 is, but I hope this helps you out some!
Seems to me like the ERG system is the culprit!
Old Jan 12, 2004 | 02:40 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
36 - MAF sensor burn-off circuit
Old Jan 22, 2004 | 03:23 PM
Greygoat's Avatar
Old Jan 22, 2004 | 04:07 PM
Vader's Avatar
Have you set the TPS voltage to something between 0.47 and 0.58 VDC? That's a good start.
Old Jan 22, 2004 | 04:41 PM
Greygoat's Avatar
yes
Old Jan 22, 2004 | 05:30 PM
Vader's Avatar
Seems I already have a few indentations in the drywall at about head-level from this one. There must be something I'm missing...
Just to verify:
  • Have you checked the connections at the distributor to make sure the ECM is getting the correct reference pulses?
  • Do you have any data scanning software or devices?
  • If so, can you check the ECM's reported idle RPM versus the tachometer indication?
  • Are you using a separate diagnostic tachometer or the dash gauge to indicate RPM?
  • Have you checked all engine and ECM grounds?
  • Have you tested the alternator output voltage for any AC voltage contingent? You can test the output directly at the stud, with your meter set for a 2V AC range. Anything more than 2.0V RMS is above the factory allowable limit, which to me is already way too high. Anything above 1.0VAC on a true RMS digital meter would be a problem for the ECM from my viewpoint. That would allow over a 3.5V P-P swing above ECM input signals that are already well below that level.
  • Have you disconnected the ECM power for a few minutes to clear the memory, then tried running it again?
Old Jan 24, 2004 | 11:03 AM
Vader's Avatar
Old May 17, 2004 | 04:19 PM
85Rock's Avatar
Car: 1985 IROC
Maybe stupid ?
What does the alt output have to do with the Idle? I have a idle problem and my alt gauge reads kind of high most of the time? Sorry to jump on this thread but good info thanks
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
pacoelrapido
Sep 11, 2015 02:41 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
