serpentine belt re-route after smog and A/C delete
Old Jan 12, 2001 | 01:02 AM
Z28Maniac's Avatar
I have a bone stock '91 RS with a TBI 305. I am going to remove the A/C and smog pump. How do I go about re-routing the serpentine belt without switching the water pump to a non-serpentine one?
'68 Camaro - Vortec 350
'85 Camaro Z28 - 305 TPI - FOR SALE
'91 Camaro RS - 305 TBI
Old Jan 12, 2001 | 07:06 AM
Nitro Don's Avatar
You can reroute the belt if you remove the air pump.There is a tech article on this site that shows a pic of the new routinging, using a different lenth belt.
I you want to remove the AC,you have to get a dummy pulley from GM.This pully was in the non-AC F-bodies.It goes where the AC was, and weighs about 2 lbs.
Email me if you want the GM part#.Its about $30 From you dealer. I have this setup on my 90 TA.
Nitro Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
B&M Transpak
Vette servo
B&M 2400 converter
TCI Trans Rebuild
Nitto Drag radials
FUTURE MODS:
The 700R4 is DEAD!!
Neeed to rebuild AGAIN!!
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
[This message has been edited by Nitro Don (edited January 12, 2001).]
Old Jan 12, 2001 | 08:18 AM
Dana92RS's Avatar
There's also a pulley to replace your smog pump. It is p/n 10186167, available from any GM parts counter. Here's a pic of it installed on my '92 RS:
Get this pulley and the A/C delete pulley and you can use the stock serpantine belt in the stock routing.
Old Jan 12, 2001 | 10:31 AM
SeanSullivan's Avatar
you can use the exsisting idler pulley, just have to go OVER it, and also change the upper radiator hose to autozones number XL449, its from a 69 camaro. If you like I can send you a pic of the way it is on my 92.
Old Jan 12, 2001 | 11:05 AM
Blade's Avatar
I'd like to see that too Sean if you're willing to send me a pic. Thanx nrgz28@hotmail.com
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 12, 2001 | 12:49 PM
done, sent pics to you.
Galaxie500XL
Feb 1, 2020 04:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
buckshot63
Sep 10, 2015 09:15 AM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
