Vacuum line on heater controls ??
Old Jan 1, 2004 | 03:17 PM
86r fixr's Avatar
Here is my question. Is there a vacuum line that goes from the heater controls to the engine?
I had a fire in my passenger side engine compartment awhile back. Since then I only have defrost . Any help will be welcome
Old Jan 1, 2004 | 03:45 PM
ede's Avatar
ede
yes, but it's been so long i'd have a hard time saying where it is. heater control valve maybe?
Old Jan 1, 2004 | 07:41 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There's two, actually. One leads from the vac port on the intake manifold assembly to the heater control head, where it is routed between all of the separate flapper doors to control where the air goes through the ducting. Not having a V8, I can only tell you that mine is on the driver's side connected between the vacuum outlet at the back of my upper plenum and the vacuum lines leading to the cruise control assembly and the vacuum tank.
Also, on the passesnger side on most thirdgens, I believe, there will be another line leading to the heater control valve from the heater control head.
It sounds like the vacuum inlet line to the control head is gone, and the defrost setting is the default setting for the head if there is no vacuum present, for safety reasons, I suppose.
Old Jan 2, 2004 | 04:10 PM
86r fixr's Avatar
Thanks for your help . I am going to try to find a vacuum diagram for my car . The crappy Haynes manual dont show jack. Now I know what to look for.
Old Jan 2, 2004 | 05:50 PM
Engine: 2.7L V6
Axle/Gears: 4.41
There should be a main vacuum diagram located somewhere under the hood unless it was destroyed in you fire. The diagram for the heater controls is here:
http://92b4crs.tripod.com/86wiring/dia-pics/63-17.jpg
Old Jan 2, 2004 | 06:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Maverick H1L,
Could you try loading that link again, it doesn't work. At least not on my system it doesn't.
The Trickster!!!!!!!!!!!!!
Old Jan 2, 2004 | 07:09 PM
Engine: 2.7L V6
Axle/Gears: 4.41
That's funny, I copied it right off of the page when I went there to get the right link. Oh well, I'll have to try again. If it doesn't work, go to the Thirdgen.org home page and go to the Tech Articles section. The link is called 86 Wiring diagrams and is found in the Electrical section of that page. When you get to the 86 Wiring main page, go down to Air Conditioning and the link is called Vacuum Controls....
Okay, so it is not working. Oh well, I tried twice...!
Old Jan 2, 2004 | 07:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Let's see if this works Maverick H1L!
It works now. What I did was go to that page and bookmarked it. I then copied the bookmark and inserted it here.
Hope this helps.
Old Jan 2, 2004 | 07:48 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
i get this
File Type: bmp
Old Jan 2, 2004 | 07:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Scottland,
Did you try the the one that I posted or the one that Maverick H1l posted?
Old Jan 2, 2004 | 08:15 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
yep.
tripod won't allow files to be accessed unless they are linked through a tripod webpage, i.e. *.html, or *.htm
so either create a small page that links to the picture., or give the address of the page that the link to the picture is on.
Old Jan 2, 2004 | 08:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I don't which link you tried Scottland, but I just tried the one in my post and it took me right to it. Anyone else have this problem?
Old Jan 2, 2004 | 09:19 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I still get the same thing. I don't get it... It worked every other time...
Anyways, I figured it out: You have to copy and paste the link for it to work.
Old Jan 2, 2004 | 09:39 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That's what I did Maverick H1l, I copied it as a bookmark and formed a link to it. Then copied the bookmark and pasted it into my post. When ever I click on the one in my post it goes right to it. This is getting stranger still, I just clicked on the link in both your posts and it goes right to it or did you change them? Scottland says they don't work for him. Maybe his computer has to form a link to that page
The Trickster!!!!!!!!!!!!!!!
Old Jan 2, 2004 | 09:40 PM
Engine: 2.7L V6
Axle/Gears: 4.41
No, I took the text in the forum and copied it directly into the Address bar in IE. Then it worked. I still am in the dark as to why that is happening... it never did that before and I have done the same any number of times...
Old Jan 2, 2004 | 09:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I've done it several times also without any problems except when I first started. Do you think perhaps there is a ghost in the system
Old Jan 5, 2004 | 03:04 PM
86r fixr's Avatar
Thanks Maverick H1L
I couldn't get anything from the links but I think the Tech article will work great when I get a chance to look at my car again
The_Phoenix
Feb 4, 2016 07:10 AM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
