why is my power steering pump pulley so damn hard to get on???
Old Jan 12, 2001 | 01:38 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
what the hell is the dtory woth the pulley for the power steering pump? i have been trying to get that god damn thing for like 20 minutes...what a bitch.
does anyone know of any tricks? any suggestions?
thanks
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Accel Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Jan 12, 2001 | 01:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's a special tool for that. It looks sort of like a crow's-foot wrench, that grabs the pulley by that groove around the hub, and pulls it off. Don't try to get it off without one, you'll just end up destroying stuff.
Auto Zone and Kragen and others all "rent" the pullers for free. Just go get one, it takes about 30 seconds to get one off with the tool. It also comes with a tool to put it back on without any beating.
Old Jan 12, 2001 | 08:04 PM
Guest
Guest
Posts: n/a
There are threads inside the power steering pump shaft, IIRC they are 3/8" SAE. Then you can just use a nut and washer to 'pull' the pulley back onto the pump shaft by holding the bolt after you thread it in, and turning the nut. The washer needs to be big enough to fit over the front of the pulley, not slip down inside it.
RB is right about taking it off, you have to have the tool.
Old Jan 12, 2001 | 08:27 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
well, good thing that i have friends that work at the local GM dealership. i just took it over there and they had the special tool. thanks though for the info.
-brian
Old Jan 13, 2001 | 05:11 AM
ronterry's Avatar
Car: '94 Corvette
Anti-Seize helps alot also.
Top one is the puller-
Bottom is the installer -
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Old Jan 13, 2001 | 08:43 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
thats a PITA job right there! even with an impact gun and a vise,good luck.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
mcquigg
Aug 13, 2015 02:26 PM
Street Lethal
Aug 12, 2015 11:33 AM
