gear drive timing gears???
could i use noisy gear drive timing gears in a 86 T/a with a 305 tpi?....will the knock sensor pick this up,,,and if so is there one that isnt sensitive enough to pick up the noise of the gears....thanx in advance
86 Trans Am,T-Tops,305tpi,7r4(rebuilt w/shift improvments&added clutches,9-bolt(2:77:,flowmaster,3" cat back,,,otherwise completely stock
Car: '94 Corvette
I think it will set off your knock sensor, but you might dig up some data about a less sensitive knock MODULE.
I know a lot of Vette guys replace the LT1 knock modules to the LT4 knock modules when they add roller rockers. The knock sensors are the same in the LT1 & LT4, its the modules that interpit the data and sends a signal to the computer.
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
You can bolt up a noisey gear drive to your cam since it isn't a roller, but I wouldn't. (personal opinion)
You can defintely use a quiet one even with a roller cam. I have been using a quiet one for years and have not had a problem with the knock sensor picking it up.(contrary to some peoples beliefs...)
You can desenstitize you knock sensor to use a gear drive, but then that defeats part of the purpose on having the sensor. To me a quiet one is loud enough and the noisey is to obnoxious.... If you want people to think you have a charger on the car, the quiet one is perfect...
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven
raven
hectre13
Aug 26, 2015 08:17 AM
