VATS?
Old Jan 11, 2001 | 05:21 PM
Blue92's Avatar
VATS?
Can anyone tell me if my vats system is bad because I was told that what my car is doing is because of a bad vats. Everything on car runs but it will not turn over. When I put the key in it the security light does not keep blinking. I also could not find the yellow wires coming from the steering column as listed in the vats bypass fix. Does anyone have any clue?
Old Jan 11, 2001 | 06:46 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The light won't blink, it will stay on steady if the system detects a fault. Its not a yellow wire, its two very thin white wires inside an orange sheath.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 12, 2001 | 01:45 PM
Pat Hall's Avatar
The wires are pretty easy to spot at the base of the column because they have their own individual plug. Just look for a little two prong plug assembly with two fairly thin wires. The plug should be about in the same spot as the big plug for the rest of you column wiring. If you do the bypass, it will more than likely solve your problem since I'd place a pretty good wager that your problem is those thin wires have broken up at the key switch where they rotate every time you start the car.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Jan 12, 2001 | 04:14 PM
Blue92's Avatar
I did the bypass thing but it didn't seem to work. My light does not stay on when the key is turned to start. My resistance measured 679 so I bought a 680ohm resistor at a 1/2watt. Was that right? Could this be any other problem? Thanks. (going crazy!)
Old Jan 12, 2001 | 06:02 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If you turn the key to run, and the light goes out after 2 seconds, then the VATS is probably OK. You may have a bad start inhibit relay, bad P/N switch, or even a bad starter. If you have a 12V test light, have somebody hold the key in the "start" position while you check for voltage at the starter (purple wire). If you have it, then its the starter, If you don't, then you need to check elsewhere.
The P/N switch is in the center console and the start inhibit relay is behind the drivers kick panel.
P.S. If you have a 5-speed, you don't have a P/N switch, but a clutch safety switch, located at the clutch pedal pivot area.
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Jan 13, 2001 | 07:01 PM
Blue92's Avatar
Thanks GMTech. It was the P/N switch. Some how in the process of putting my console back together the harness came out and was pushed behind my radio with all the other wires. I plugged it in and the car started right up!
<A HREF="http://albums.photopoint.com/j/View?u=1229597&a=9072781&p=29492901
" TARGET=_blank>http://albums.photopoint.com/j/View?u=1229597&a=9072781&p=29492901
</A> Harder"
Stock 305TBI,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft
Old Jan 14, 2001 | 07:46 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Cool.
Let me guess, my mentioning the "center console" rang a bell in your head.
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
--&gt;14.97 @ 94.9 MPH&lt;--
'97 Bonneville SSE
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
