Block Paint Question
Old Jan 4, 2004 | 03:42 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
When I swapped in my new engine block, I painted the block black because I heard that the compounds in black paint facilitate better cooling. Has anyone else heard this? Just curious if I was fed a line of BS or not.
Old Jan 4, 2004 | 03:47 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
Black is the color that I'm going to paint my 388ci. Its the only color I'd paint a motor(helps hide oil leaks).
Old Jan 4, 2004 | 03:48 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
I've also heard painting the block black helps with cooling. I wouldnt enjoy the fun of tracking down a small oil leak though!
Old Jan 4, 2004 | 05:04 PM
ede's Avatar
ede
what i always heard and it makes sense
Old Jan 4, 2004 | 05:42 PM
Nixon1's Avatar
Good...I've got no worries then..
Old Jan 4, 2004 | 05:55 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Couple of turbo-obsessed guys I know never paint their blocks because they say any form of paint hurts its ability to cool. Who knows, but when you're building 500HP 4-cylinder turbo motors maybe every little thing helps
Old Jan 4, 2004 | 07:39 PM
Pat Hall's Avatar
At the shop I used to work for, we had these little vials of flourescent dye we poured into the motor oil. Then you just use a blacklight and shine it around different spots on the motor, and you could usually spot oil leaks very easy. Essentially the same method used to look for leaks in the a/c system.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
