Head Lights Not Comming Up
Old Jan 12, 2001 | 06:23 PM
Skip Howard
Guest
Posts: n/a
I've replaced both relaysfor the motors and no luck. You can hold the headlight switch half way in and the lights will come up with ni problem. I tried a new switch and no luck there either. Is there another relay I'm missing?
Old Jan 12, 2001 | 08:07 PM
Vader's Avatar
Skip,
There is a master, or "isolation" relay that controls both individual actuator motor relays. I had a be-otch of a time finding the relay on a Fiero, and have never looked for it on my TA. I'm guessing you'll find it in the driver's footwell area.
The circuit looks like this:
If you find the relay with the correct color wiring, you've probably found the isolation relay.
If you raise the actuator(s) with the hand *****, do they try to immediately retract? This would indicate that the individual relays are functioning correctly, and the master/isolation relay is suspect.
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Old Jan 13, 2001 | 01:29 PM
Skip Howard
Guest
Posts: n/a
Yep! If I put them up manually they'll go back down if I don't disconnect the relays. I'll start digging for the isolation relay. Thanks too for the diagram. I'll definatly be adding it to my ever growing notebook on my baby!
Old Jan 13, 2001 | 06:04 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Um, on my '85 T/A it was in my friggin' spare tire compartment. Anyone else?
Old Jan 14, 2001 | 11:36 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Are you saying that there is a grand total of three or four relays for the entire headlight system? I've found only three, but I bypassed them all.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Vintageracer
Jan 10, 2020 05:33 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Omega
Aug 10, 2015 12:46 PM
