Code 32 & 33, HELP!
Old Jan 13, 2001 | 07:01 PM
FRDH8R's Avatar
Code 32 & 33, HELP!
Ok...this is what's happening. When I start the car, it idles low and erratically (even a cold start) like it's about to stall. Then after about four seconds, the service engine light comes on and the idle is smoothed out, but a little higher than normal. Then the car drives fine, but with the SES Light on.
I pulled the code, and it flashed 32 and 33. Can I get any help on what those are and possible fixes? Thanks in advance.
My 91 RS
Nor-Cal Crew For Life
Old Jan 13, 2001 | 10:28 PM
Dan91Z's Avatar
The 32 code could be a fault in your barometric pressure sensor, exhaust gas recirculation valve diagnostic switch, or electronic vacuum regulator valve
The 33 code represents a high voltage level at your maf or map sensor, or low vacuum at your maf or map sensor.
Old Jan 13, 2001 | 11:01 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Are you burning your own eprom by any chance? I was getting Code 32 today. Looks like it is TunerCat V 1.61 that is causing it. Went back to version 1.60, re-did the changes to the eprom, worked like a hot damn.
Old Jan 14, 2001 | 09:46 PM
FRDH8R's Avatar
Dan....
How can I go about checking those? Or replacing them?
My 91 RS
Old Jan 15, 2001 | 01:54 AM
Dan91Z's Avatar
do you have a gague to check the vacumm? if you can check that and it turns out to be the problem, most of the time you can just snip the hose a little if the leak is close to an end and put it right back on
the vacuum should be around 18psi i think.. not to sure though...
as far as the map/maf goes, i always use a computer form snap on tools to display the readings form that sensor and just check to see if it is where it should be.. You can do this with a volt meter, but I don't know what the voltages should be right off..
those 2 things above would probably be the most likely cause of the 2 codes.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
