tps problem?
Old Jan 5, 2004 | 01:27 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
tps problem?
if my car sits for 30 min it will start up and drive fun. but after 20-30 mins it will sputer and i will have a dead gas pedal and then it will die. Somtimes i can get it to run again, other times i start it and it sputurs for alittle and then dies. but if i go back like 30- mins later i can start it and drive again. I changed my starter, coil, and map sensor. what do u guys think?
Old Jan 6, 2004 | 05:55 AM
ede's Avatar
ede
i think you're replacing parts without any trouble shooting. you ought to make sure the tune up is good, filters ok, no vacuum lines broke. scan it for codes.
Old Jan 6, 2004 | 10:32 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
A bad ignition module can do that.
Old Jan 6, 2004 | 02:07 PM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
I agree, mine did the same thing and it turned out to be the pick-up module. The second time I had the similar problem, it was due to n aged connection at the FP relay.
92camaroJoe
Jul 29, 2023 07:57 PM
GTAman
Sep 21, 2015 09:57 AM
soarestransam
Aug 24, 2015 08:15 AM
92camaroJoe
Aug 13, 2015 06:07 AM
