purchasing flywheel to torque converter bolts
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
where can i purchase some torque converter bolts that bolt through the flywheel and to the torque converter. if i cant get these at an auto store, how bout a hardware store? and wut size or grade shall i get
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
If you can use bolts with nuts, check out these from ARP:
http://www.jegs.com/cgi-bin/ncommerc...94&prmenbr=361
Car: 1989 C4
Axle/Gears: 307
All the parts stores carry them in the Chrome Isle. Its around $8 for a set of grade 8 bolts with lock washers, they even come with nuts if your tq converter is the style that requires them.
1992 Trans Am
May 10, 2023 07:19 PM
