Rear end swap.
Old Jan 15, 2001 | 06:25 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Rear end swap.
I want to put in 3.43 in the rear end. I have the stock drum brake rear end on a 89 TA. I was wondering if I should buy a whole new rear end from a wrecker with the disc brakes?? Is it worth the time??
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Jan 15, 2001 | 08:26 AM
ede's Avatar
ede
the rear disk on a thirdgen aren't that good a brake set up. i doubt if you'll see much if any improvement. i wouldn't do it, in fact i had the rear out of my car last summer and have a extra disk rear laying around and never swaped.
ICON Motorsports
1st & 3rd
Old Jan 15, 2001 | 11:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Th early style disk brakes absolutely sucked. I would not downgrade from drums to those, which came on 10-bolts before they started using the 9-bolt, and on all the 9-bolts. There was some sort of modification / retrofit done to the pistons that involved the parking brake, it helped but was far from a cure. If you want to do a rear disk swap and have it be an upgrade, get a 10-bolt from a 91 or 92 with the PBR calipers.
You'll spend a long time looking for that rear with those gears, however. Very few cars came that way, and the rears are highly sought after. You'll have more luck looking for the rear itself and then swapping the gear of your choice into it.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
