HEAD QUESTION
Old Jan 15, 2001 | 03:47 AM
HIX5000's Avatar
HEAD QUESTION
Recently I pulled my plugs to check them, and they were all covered in oil. There was no oil on the combustion chamber side just on the plug wire side. I think the oil may have poured in there while I was setting the lash on my rods, but i'm not sure. There was a substancial amount of oil on every plug. Do I need new heads? Is there a good way to check?
1988 Camaro RS
2.8L five speed
Money pit from hell!!
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
Old Jan 15, 2001 | 04:21 AM
Pat Hall's Avatar
Doesn't sound like a head problem at all. You either spilled a lot of oil down the heads while adjusting your lash, or you have some seriously leaky valve cover gaskets!
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Jan 15, 2001 | 04:25 AM
HIX5000's Avatar
Cool thanks pat. Any ideas on getting the oil out or can I just let it burn off.
1988 Camaro RS
2.8L five speed
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
[This message has been edited by HIX5000 (edited January 15, 2001).]
Old Jan 15, 2001 | 11:18 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
why are you setting lash on a hydraulic cammed engine (I assume by rods you mean pushrods?). Here's what I think happened, you have leaky valve covers and thats where the oil is coming from.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter.
13.24@104
[This message has been edited by vortecfcar (edited January 15, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
