need to install an aftermarket fuel pump
Old Jan 8, 2004 | 02:53 AM
jfawcett10's Avatar
Car: 1987 Formula Firebird
Engine: 350carb
Hi, this is kind of a stupid and weird post, and i search but cant find what i need...
But i bought a carter fuel pump, summit #crt-m6900
i have a mechanical fuel pump with one steel line, one fat rubber line, and one skinny rubber line...
the carter fuel pump has two steel screw in holes...
How am i supposed to connect the two rubber lines to the single steel screw in hole?
What do each of the three lines do?
thanks for any reply!
Jarrod Fawcett
Old Jan 8, 2004 | 04:48 AM
ede's Avatar
ede
third line is a return to the tank most likely. buy a hose barb fitting that'll screw into the threaded hole in the pump. it should be for a flare fitting, you might have to go from flare to NPT and then from NPT to barb. might be easier to buy the correct pump for your application.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
92camaroJoe
Aug 13, 2015 06:07 AM
