Line from AIR to Converter ??
Old Jan 8, 2004 | 08:47 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Has anyone replaced their line that goes from the AIR pump to the converter? Mine got bent up and i would like to replace it with a nice looking alternative. (Yah, I know it not really seen, however, I like anything i do to the car to look "trick" if possible.
Basically those that have replaced it what did you use from the check valve to the converter?
I would assume that braded stainless would not work due to the heat near the converter.
Old Jan 10, 2004 | 05:05 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
There is a new material that came out about a year ago. It looks like a rubber hose but the tube connects to your Cat onstead of the chrome one that was on it. It will not burn or melt and chemicals will not hurt it. Check your local muffler shop for the name of it they most likely will have it in stock,
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
dyeager535
Aug 28, 2015 08:10 AM
mdtoren
Aug 23, 2015 12:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
