Web site to look up ACDelco part numbers?
Old Jan 15, 2001 | 08:54 PM
My Slow Iroc-Z's Avatar
I just bought an ACDelco CTS for an '89 L98 and the part number is 12146312. Is this the correct part? Reason I ask is that the parts guy said it was for a 5.0 liter TPI but I have a 5.7. They don't return electrical part eighter if they were installed.
1989 Iroc-Z L98 Original engine-58K miles!!
SLP 1 3/4 SS headers, Hooker Areochamber catback, no cat, BBK AFPR, 3.8L Turbo V6 200* fan switch, MSD GM coil, ported and gasket matched plenum, TB coolant bypass, relocated MAT sensor, screenless MAF sensor, K&N filters, Accel cap and rotor, Taylor SpiroPro 8mm wires, Bosch Platinum plugs, Mobil 1 oil, and more to come...
Best ET not corrected- 14.24@96.76MPH / 2.17 60ft on street tires with the crappy B/W 2.77 gears.
Homepage currently under construction: http://www.iit.edu/~wicktho/len
Old Jan 15, 2001 | 09:58 PM
Vader's Avatar
Slow,
The CTS resistance ranges haven't changed for about eleventy-seven years, along with just about all other GM temperature sensors, whether they are IAT, MAT, CTS, whatever they are sensing. The big differences are the sensor body size and threads, and the electrical connector styles. If it fits your connector, it's the right one.
As for the parts lookup, there is no direct site that gets you into the GM Bell & Howell parts catalog system. If you know the part number, there are a few sites where you can plug in the number and find the application, but not to lookup parts for your application in every case.
I wish someone would find a back door into the Bell & Howell system so people could find the part numbers, applications, diagrams, availability, etc. (Hint-Hint!)
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 15, 2001 | 10:03 PM
Vader can you post a few sites for me? I tried wrenchhead.com and carparts.com but they don't have that part number 12146312.
Thanks!!
Old Jan 15, 2001 | 10:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I wish there was! AC/Delco has one of the lamest sites in the whole automotive world.
Old Jan 15, 2001 | 10:16 PM
Vader's Avatar
http://www.gmpart.com/
http://www.worldparts.com/auto/
Later,
Vader
KaleCo Auto Parts
Old Jan 15, 2001 | 10:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Actually other than style and size, there is 2 types of sensors. One is for a guage. The other for an idiot light. I've seen people use guage sending units with idiot lights. As the temperature rises, the idiot light gets brighter.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jan 16, 2001 | 11:57 AM
Vader's Avatar
Stephen,
I gues you could call them "sensors" in a purely technical sense. I call those digital devices "temperature switches" and the analog devices "sensors", even though they both sense a condition and act on it.
I guess it's just a throwback to the days when we called everything a "switch" because tha's all most of them did.
Later,
Vader
KaleCo Auto Parts
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
