400 questions
Old Jan 15, 2001 | 08:02 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
400 questions
whats the ccs on a sbc 400head? i can't find on the piston if its standard or oversized.its a gm piston so i'm hoping the blocks not been bored
Old Jan 15, 2001 | 08:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Usually 882 smog heads with 76 cc chambers. The factory didn't build high compression 400's or any with 4bbl.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jan 15, 2001 | 10:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Stephen is being charitable I see.
The heads the factory put on a 400 are garbage, pure and simple, regardless of the ccs. If you ever come across a complete 400 motor they should be among the first things you set out by the curb, along with the M2MV carb and the joke intake. I have a set of 186 (double-hump) heads on mine, but if I were doing it all over again, I'd go aftermarket. Back in the Civil War days when I first built this thing, there weren't any Edelbrocks, or AFRs, or Fast Burns, or any of the rest of that cool stuff we can just go down to the corner and buy.
Just for reference, they're 76 cc, the same as the crap that made mid-late 70s 350s with a 4-barrel have 170 HP. The bore (the thing you need to check to see if it's been bored) is 4.125".
Good luck!!! Maybe you get to join the club of the people with THE BIG ONE.
Old Jan 16, 2001 | 02:37 AM
burnoutrpm's Avatar
they're 76 garanteed the 400 from the factory wasn't never meant for performance . like the other guy said the stock heads are crap! plain and simple what ever you put back on there be sure to steam port them or you'll have worlds of fun with overheating. and you should be able to tell if they're overbore by looking at the top or sides of the pistons(usually the top). usually a gm piton indicates its astock bore:-) goood news for you . i myself am going to biuld a 400 too. letme know if you need any help further i would be glad to help you or anybody else for that matter .
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 intake.
Future mods performer rpm air gap intake (polished) and 600 edlebrock carb, comp roller cam, and way better headsa 400 defintely in the works!
Old Jan 16, 2001 | 10:07 PM
zenish's Avatar
Engine: 305 tbi
i was wanting to run vortec heads,but my pistons are already dished so their 64 cc chambers may put my compression too high
camaro71633
Sep 1, 2015 10:24 AM
downsouthboy
Aug 29, 2015 11:29 AM
lakeffect2
Aug 23, 2015 08:44 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
