oil everywhere!
Old Jan 16, 2001 | 04:22 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
oil everywhere!
Yesterday I overheated my engine when a heater hose blew. the temp gauge read 220F
but about 2 1/2 gallons was lost.
Now today after starting the motor and letting it run i backed it out only to find a huge puddle of oil! i put it up on jackstands and oil pisses out in a steady stream when the engine is running. as soon as i shut it off the oil stops leaking.
the oil seems to be seeping out from between the block and the bellhousing.
Im thinking rear crank seal or cranked block?
is it possible it could be something less serious??
ack!!!
Old Jan 16, 2001 | 04:49 PM
ede's Avatar
ede
oil sender, above oil filter and/or next to the distributor. split oil filter, or oil plug came out. lot of things might of happened, you need to clean it up and start looking.
ICON Motorsports
1st & 3rd
Old Jan 16, 2001 | 09:05 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
Pulled out the sender, its wasnt leaking, the oil filter isnt leaking either, the leak is coming from above the filter seeming like from the sender, but lower, from the head??
valve covers arent leaking, the back of the manifold is dry.
help!
Old Jan 16, 2001 | 11:54 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
ttt
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
