Rear End swap; 3:08 drum to 3:42 disc?
Old Jan 17, 2001 | 12:07 PM
rusty Z's Avatar
I have the opportunity to replace my sad 3:08 open rear with drums over to a 3:42 posi with discs. Can this be done easily? Will all the same lines work for me? By the way it's an '85 to '85 swap. Please advise
'85 Z28 Copper/ Gold, LG4
dual snorkel w/ ram air, Accel Cap Rotor and 8MM wires, Edelbrock Headers, Catco Cat, Flowmaster 80 series
American Racing Wheels. 350 crate in the future.
Old Jan 17, 2001 | 04:01 PM
JeffT's Avatar
Car: 1991 Z28
should be a straight forward swap. Be sure to get the e-brake cables for the disc rear as this is the only thing that should be different.
Old Jan 17, 2001 | 05:17 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You will need the master cylinder and proportioning valve for the 85 disc brake setup as well, as it is different than the drum setup.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 18, 2001 | 11:32 AM
rusty Z's Avatar
The parts car I am getting the rear from had discs on it. The master cylinder is still there. Do I need the whole thing? Is that swap very difficult? Please advise. Thanks!
Old Jan 18, 2001 | 12:53 PM
JeffT's Avatar
Car: 1991 Z28
Thank you Kevin. I must have dosed off at the keyboard.
Rusty, just to be on the safe side you may want to just get the master cyl./brake booster assembly along with the proportioning valve. But at least get the master and proportioning valve. Should be two bolts holding the master on and remove the brake lines and that's it.
hectre13
Dec 11, 2023 08:14 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
