Fan/PROM conflict
Old Jan 18, 2001 | 06:26 PM
theformula's Avatar
Fan/PROM conflict
Ok, heres the thing. I have a fastchip stage 2. The fan kicks on at 176 and turns off at 166.
I want to run a 170* t-stat. Seems like not a problem since 170 degrees is cooler than when the fan is supposed to come on (178*)
My worry is in the summer...if the car goes over 170* the fan will kick on. I am trying to avoid a fan/Prom conflict.
I live in Delaware where we have cold winters and hot summers. So people with low degree T-stats, (160/170), what does your temp gauge read in the summer?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Cold air ind. w/K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, SLP headers & catback,short shifter,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Jan 18, 2001 | 08:05 PM
My Slow Iroc-Z's Avatar
You cannot use a 170 degree stat if the fan turn off temp is 166 degrees. Think about it, what does the theromstat do??? It blocks the cooled water from the radiator from entering the engine and cooling the engine at a preset temp. If your thermostat is just about closed at 170 degrees but the fan turn off temp is at 166 degrees theroically the water temp will never reach that low of a temp and the fans will never turn off. If I were you I would use a 160 degree stat and not have to worry about replacing your fan motors every year from constant use.
1989 Iroc-Z L98 Original engine-58K miles!!
SLP 1 3/4 SS headers, Hooker Areochamber catback, no cat, BBK AFPR, 3.8L Turbo V6 200* fan switch, MSD GM coil, ported and gasket matched plenum, TB coolant bypass, relocated MAT sensor, screenless MAF sensor, K&N filters, Accel cap and rotor, Taylor SpiroPro 8mm wires, Bosch Platinum plugs, Mobil 1 oil, and more to come...
Best ET not corrected- 14.24@96.76MPH / 2.17 60ft on street tires with the crappy B/W 2.77 gears.
Homepage currently under construction: http://www.iit.edu/~wicktho/len
Old Jan 18, 2001 | 08:09 PM
Oh yeah...just to let you know the temp guage in these cars is useless....if you really want to know the engine's temp...back probe the CTS at the front of the manifold and match the resistance you get with the chart on this site, if you do a search you should be able to find it.
Larry 89GTA
Aug 24, 2015 07:47 PM
theformula
Aftermarket Product Review
Jan 20, 2001 01:25 PM
theformula
Jan 18, 2001 10:10 PM
87/88Firetruck
Jan 17, 2001 02:28 PM
Wishmaster's87IROC
Oct 30, 2000 09:06 PM
