Fan/Prom conflict
Old Jan 18, 2001 | 06:24 PM
theformula's Avatar
Fan/Prom conflict
Ok, heres the thing. I have a fastchip stage 2. The fan kicks on at 176 and turns off at 166.
I want to run a 170* t-stat. Seems like not a problem since 170 degrees is cooler than when the fan is supposed to come on (178*)
My worry is in the summer...if the car goes over 170* the fan will kick on. I am trying to avoid a fan/Prom conflict.
I live in Delaware where we have cold winters and hot summers. So people with low degree T-stats, (160/170), what does your temp gauge read in the summer?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Cold air ind. w/K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, SLP headers & catback,short shifter,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Jan 18, 2001 | 09:31 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Yes, the turn off speed will never be attained once the fans have been engaged so they will remain on until your turn off the engine.
BTW, the reason the fan off temperature is always 5-6*F higher than the T-stat is because of the variation from T-stat to T-stat. With my Diacom I can see the difference in the T-stat opening and closing and it varies all the time within 5-6*F.
Old Jan 18, 2001 | 09:51 PM
theformula's Avatar
Looks like I'm stuck with this 160*!
Old Jan 18, 2001 | 10:10 PM
Car: Death Mobile
Engine: 666 c.i.
Could look at getting the chip reburnt or reprogrammed. But for the time being, yeah, looks like your stuck with a 160.
[This message has been edited by Glenn91L98GTA (edited January 18, 2001).]
Larry 89GTA
Aug 24, 2015 07:47 PM
theformula
Aftermarket Product Review
Jan 20, 2001 01:25 PM
theformula
Jan 18, 2001 08:09 PM
87/88Firetruck
Jan 17, 2001 02:28 PM
Wishmaster's87IROC
Oct 30, 2000 09:06 PM
