Crank question
Old Jan 15, 2004 | 08:46 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Crank question
hello everyone, I purchased a gta with a bad engine. engine can not be rebuilt. I have a complete 350 block ( a 350 is a 350 ) the internals however are not. the engine came out of a late 80's truck and I was wondering about the crank? What kind of crank would be found in a 89 gta? I am trying to put this car back to stock with maybe a mild upgrade.
Old Jan 15, 2004 | 09:35 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Both should be 1-pc rearmain seal cranks..assuming "late-80's".
Old Jan 15, 2004 | 09:47 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The only right thing to do is to look up the casting numbers on a site like www.Mortec.com
The casting numbers on older blocks are on the driver's side of the block where the tranny bolts on.
One a newer block they're the passenger's side where the tranny bolts on.
If you chose to swap cranks, keep the rods and crank together AND mark the rods according to what cylinder they came out of. The rods and crank are balanced from GM, and you'll want to save some time and money by keeping it that way.
Old Jan 16, 2004 | 07:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Chances are, if the truck was a 87-up TBI 350, it's got the same crank casting # as the GTA. Both kinds of engine had cast-iron cranks.
Like AJ said, keep the moving parts from each engine together as a set if they're still a factory set, it'll save you some trouble and grief in the long run.
Old Jun 2, 2004 | 08:41 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
86-up
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
