engine
engine
when the engine is started, after about 10 seconds i can hear a whining nosie comming from my oil pan. right now i'm in the process of dropping the the oil pan to see whats up. are there any opinions of what i might fine or what to look for to help me solve this problem.
engine
the noise might be a cyclical screetching sound ? today i pull the oil pan off and what i found was the coating wore off some of mains and rod bearing. i have put two different rebuilded l98's in this car and i am having the same problem. all needed crankshafts
do these engine take tight are lose clearances. one thing i fail to replace was the engine oil cooler. could the oil cooler be contaminated. my oil pressure was 60 psi at start up and 40 psi when warmed up.
Car: 91 RS
Engine: 305 Tbi (L03)
Considering its the second engine with the same problem its probably the oil cooler. If its restiricted, the extra load on the oil pump could make a sound similar to the one you describe.
84z96L31vortec
Aug 20, 2017 12:16 AM
