Quick question
Old Jan 21, 2001 | 01:46 AM
XxMoLexX's Avatar
Quick question
I got a stoopid question, ill prolly get a bunch of stoopid answers (and yes i know its spelled stupid) I saw something in an older post about manually shifting a auto. They were saying somethin about blipping the throttle. im jus curious as to wat exaclty it means. jus a quick tap of the gas before the shift?
91 3.1 RS.
T-Tops
12" tube in the trunk
16" ROH Rims (Need Center Caps) ROH Rims
Firehawks all Around
Old Jan 21, 2001 | 01:58 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
There are no stupid questions, only stupid people.
- Mr. Garrison
I'm not sure what blipping the throttle means. Do you mean manually shifting in a race or just all the time? I wouldn't do it all the time but when racing just keep the throttle down. They might have been talking about the 3-4 shift (or lack thereof) - there's really no good way around this other than to buy an upshift sleeve.
89 Iroc-Z LB9 TPI auto 2.73 posi:
3" Dynomax muffler, K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, accel 300+ wires, cap&rotor, synthetic oil, flexlite transmission cooler, afpr, !air pump&diverter valve, kicker sound system, soon to attempt engine swap...
Old Jan 21, 2001 | 02:17 AM
XxMoLexX's Avatar
thanks for understanding. Im not sure what they meant either. the post said something about blipping the throttle jus b4 u shift to get a nice clean shift. i always figured just throw it up to the next gear with the foot on the gas.
just curious
91 3.1 RS.
T-Tops
Old Jan 21, 2001 | 02:36 AM
JPrevost's Avatar
Car: 91 Red Sled
I've never heard that before.
, Jon (91 RS too many mods to list), getting new engine in summer
Old Jan 21, 2001 | 02:43 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
I think I know what it means come to think of it. When you've got the gas all the way down and shift up, say, 2-3, there's a brief lapse between shifts - having not driven the IROC in a month I forgot about this!! If you let off the throttle slightly it's crisper but that would be very tough to time properly. It sounds intriguing, I think I'll give it a try.
[This message has been edited by I ROCK (edited January 21, 2001).]
Old Jan 21, 2001 | 03:00 AM
Josh 91RS's Avatar
No No No...theyre talking about when downshifting manually. If you manually go up and down the gears, when downshifting you have to tap the gas a little right before you downshift otherwise it wont engage right away. If you give it a little "blip" then downshift, it engages right away and you can feel it go into gear...if you just pull it down a gear without "blipping" the throttle it wont go into gear right away, it will take a few seconds, then kinda slam into gear. At least thats what it does in mine. I read the same thing a few days ago, tried it out, and sure enough...
Old Jan 21, 2001 | 03:05 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Oh yeah that makes a lot more sense. Although you shouldn't downshift an unmodified 700R4 from 3-2 or 2-1 b/c the ratio difference is too steep and you could cause damage. The 4-3 is ok though. Hell, I still downshift to 2 if there's a mustang or ***** nearby and I'm far enough below 70 that I won't overrev...lol.
Old Jan 21, 2001 | 09:03 AM
Vader's Avatar
IROC,
What's "second"?
(Lexx said he expected some "stoopid" answers - I just wanted to oblige...)
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 21, 2001 | 09:08 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
What in the world are you talking about? (Pay no attention to that little message below my signature above...)
I'm pretty sure it's obvious, but I wasn't accusing the poster of being stupid, and the question wasn't anyway...
Old Jan 21, 2001 | 10:52 AM
Vader's Avatar
U ROCK,
Jus' pullin' yer chain a bit, dude. I didn't think anyone NEEDED second gear to beat up on a *****...
And I didn't mean to imply that your response (or the question) was "stoopid". Just trying to keep it light. Besides, the coffee hasn't kicked in yet...
Later,
Vader
KaleCo Auto Parts
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
