Another Strange Noise
Old Jan 18, 2004 | 12:37 AM
Insaniac198's Avatar
Car: 1999 Trans Am
I guess I would have to describe it as a drone/loud humm type noise. It does it only under WOT, and only when the car is in gear. At first I thought exhaust leak, but no noise when I rev while in neutral. The catatlytic converter is new, so I ruled out a clogged cat. Also, I have Hedman headers and their y-pipe, so the exhaust has to make pretty much a 90 degree bend to clear the SFCs. Not sure if that could cause it or not.
Old Jan 18, 2004 | 07:16 AM
ede's Avatar
ede
tire, something in the drive line, or exhaust vibration
Old Jan 18, 2004 | 02:05 PM
Car: 1999 Trans Am
Forget to add something:
There is also a noticeable bog/power loss when this happens. For example, downshifting from 3rd to 2nd at about 30 mph under WOT. It'll make the noise, bog, then finally go.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
BWilcox
Sep 20, 2015 12:19 PM
