Does anyone know how to...
Does anyone know how to remove the turn signal lever in our cars? My broke so I got a replacement. Do I have to tear apart the steering column? I have the steering wheel off, but how do I remove that plastic cover on the column?
give it a 1/4 to 1/2 turn back towards you, or counter clockwise looking in on it. i can't remember what way to turn it. just start twisting and it'll come lose. it just locks in a groove.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Car: yep
Engine: uhuh
Transmission: sure does
I thought they just pulled straight out??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
It comes straight out, NO turning. Make sure all your cruise control, wiper modes are turned off, and that it is in the middle, not downward for left turn signal or upward for right turn signal. If any of those apply, it will not come straight out. This is assuming that all turn signal levers for all third gens are the same. I just changed mine out.
1989 IROC-Z 5.7L
1989 IROC-Z 5.7L
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Attach a piece of line to the end of the turn harness. Or you will never be able to fish the new harness hanging off the stalk down the steering column.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
It pulled straight out. The new one slid right in. I cut the old harness and taped the new one to it and tried to pull it through the column...wouldn't work. I eventually got fed up with it and cut the new harness 3" before the connector. I then taped it to the old harness and it slid right through. I soldered the connections and it works just fine. Thanks for the help. This proccess wasn't in my Haynes manual at all. Is there any other manual that is available that is more detailed when it comes to our 3rd gen. repair?
Demon Z28
Pacific Northwest Region
32
Jun 25, 2001 08:05 PM
