How Much.......
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I just had my 383 stroker rebuilt and it cost me around 1700, but I mean it is really nice. They tri- angle ported the heads, bigger valves, new springs and rods, new piston rings, honed and cleaned all my parts, put in an edelbrock performer rpm cam, rebalanced the crank, new timing chain, all new seals and gaskets, they pre lubed it and put a filter and oil in it. So it seems like alot of money up front but what you get in the long run is worth it.
Car: 95 Trans Am
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If the car is jsut going to be used as a daily driver and you plan on keeping it for a long time then a new/rebuilt 2.8 would be worth it. If your going to be getting another car in the present ones place then you might as well hold off on another engine and see if the 2.8 you have now can be made to go farther. Another option is to get one thats a bit more fresh from a junk yard. Lot cheaper and it would keep you going a bit longer while you save up for another car.
