AFR 190's or 195's??? And w/ what Intake Manifold?
Old Jan 20, 2001 | 05:35 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
Hey guys. The Z is up on stands for the rear end swap and while it's up the SLP headers, Random cats, intake/runner gasket matching etc. is getting done. I'm really contemplating getting some AFR heads and Crane 1.6RR too. I plan on building a 383 pushing approx. 425-450 hp and torque. Would the AFR 195's be a good setup for the 383 w the 1.6rr, and if so, would it work well with my current L98 350 (mods in sig) too while I gather enough $$$ for the 383? Also, what intake manifold would work best for this setup? Thanks for any input....I'm learning about the valvetrain as I go along.
1992 25th Heritage Z28 Red/Black - L98 350
- Flowmaster 3" cat-back, SLP runners/headers etc, Bosch 36lb inj, MSD ignition, TPIS 52mm TB, Stewart polished pump, ported intake.
Panasonic/Audio Control/ADS/Alpine stereo
In the Works:
Hotchkis LCA/panhard rod, Baer 13"/12" upgrade, SLP 17" chrome SS rims w/GY F1's, 4th Gen 3:73 HD Zexel/Torsen, Moser Rear End, Spohn Torque Arm/LCA RLC brackets, all MOOG front pieces, Hellwig solid fr/r bars. etc.........
Old Jan 20, 2001 | 06:17 PM
Blade's Avatar
Red and black on that 25th anniversary huh! It must look good!!! Hehe Got any pics ?
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 20, 2001 | 06:18 PM
Blade's Avatar
With a 383 I would get 195s. The best would probably be a miniram manifold from TPIS and a ZZ9 cam or a compcams xtreme like the one you see in my signature. You will see low 12s with that combo and a good exhaust.
Old Jan 21, 2001 | 02:09 AM
Dan87IROC-Z's Avatar
I would reccomend the AFR 195s as well for the 383. I am assuming you want to keep the TPI set up and not go to a mini- or super- ram. In that case, the best intake base manifold is the TPIS Big Mouth one. I would recomend the LT4 Hot Cam, TPIS ZZ9 or maybe the larger of the SLP/Summit Cams depending on your drive train.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 3.08:1 Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.6:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Old Jan 21, 2001 | 09:41 AM
Engine: 6.3L - 383
Blade, I emailed you the only pic of my Baby I have outside....I have a ton of pics while we have been working on her, also I have a few pics of someone else's that looks identical to mine. You're baby looks Sweet too, I have always loved Black/Red too!!!
Dan87Iroc-Z and Blade, do you think the 195's would work well on just the current mods I have to the L98 with some 1.6RR's? I was thinking about getting the heads soon and installing them on this engine until I have enough $$$ to build the 383. Or would they be too much for this engine and should I just wait to get them until the 383 is complete?
- Flowmaster 3" cat-back, Random Tech cats, SLP runners/headers etc, Bosch 36lb inj/4+ plugs, MSD 6A/billet dist/8.5 wires/Blaster coil, TPIS 52mm TB, Stewart polished pump, ported intake.
- Stereo: Panasonic/Audio Control/ADS/Alpine
Currently In the Works:
Old Jan 21, 2001 | 11:13 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
This is just my opinion, but I would go with the 190's. I'm building my 383 right now, you can see some of the mods in my signature. Anyway I was using the desktop dyno software two weeks ago and for a stock TPI setup with the cam I chose and the AFR 190's it gave me about 408 hp and 488 ft/lbs. of torque at only 2,000 RPM's. I know Desktop Dyno isn't totally accurate, but don't forget the numbers I got are for a stock TPI setup, and I'll be using a Super Ram and Edelbrock baseplate.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Old Jan 22, 2001 | 12:46 AM
89bonestockiroc's Avatar
I too am getting a 383 in the near future. I have to keep my tpi system because of the emissions here in california. I was thinking about about using afr 190 heads as well. They are what the engine shop recommended to me. I plan on using a tpis big mouth manifold and as&m large tube runners on my setup. Does anyone know of a better combo for a 383?
88SS6SPEED
Nov 11, 2015 07:05 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 12, 2015 10:43 PM
buckshot63
Sep 10, 2015 09:15 AM
Dialed_In
Aug 20, 2015 01:45 PM
