Will the LT cam work with upgraded vortec heads?
Old Jan 19, 2004 | 03:53 PM
bes217's Avatar
Will the LT4 cam work with upgraded vortec heads?
I was wondering if the LT4 cam will work with upgraded vortec cylinder heads that can handle .525" lift. Namely these:http://www.sdpc2000.com/cart.asp?act...d=277&pid=9063 from Scoggin-Dickey. Should I use 1.5:1 ratio roller rockers or 1.6:1 ratio roller rockers. These heads and this cam will be going on a GM performance parts L31/ 4 bolt main short block, which can also be found at scoggin-dickey. Thanks a lot.
Old Jan 19, 2004 | 06:39 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You should call them and ask. They're the ones that modify that head, so they'd know more about it. GM has nothing to do with it.
More than likely you'll need to use the springs that come in the stock LT4, or the Hot Cam kit, which I'm sure they'll do for you if you pay them.
Old Jan 20, 2004 | 09:00 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Actually I am 90% sure that the upgraded springs they put on their Vortecs are the 1.32" LT4 valve springs. Also, with 1.6 rockers the LT4 hot cam will be exactly .525 lift
Old Jan 20, 2004 | 09:17 PM
AJ_92RS's Avatar
All the more reason to call them.
Old Jan 20, 2004 | 10:54 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
The add says they are the "Z28" springs, which they sell elsewhere on their site for like $25 for the set. They are 1.25 dia springs I do believe, I have not heard much firsthand experience but several people here seem to not think too highly of them.
Kinda seems to me like you might be pushing it a bit running right at the springs maximum rated lift (of course in other kits of these modded Vortecs from Scoggin they say these same springs are good to .550, so whos to say...).
Old Jan 20, 2004 | 11:26 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
according to this question the cam stated is the lt cam there are three cams that can qualify,Lt1 cam,Lt4 cam and the Lt4 hott cam the only cam that requires the Lt4 hott springs is the hott cam due to the 492 lift w/1.5 rockers but the cam really works better with the 1.6s that will bump the lift to 525 lift.the seats of course need to be cut larger,the guides need to be cut down,the studs need to be pinned or replaced with screw-in studs.....
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
