is 160 psi a good compression reading for an 85 blazer 350???
Old Jan 21, 2001 | 10:30 PM
Josh 91RS's Avatar
Ive got an 85 blazer 350. Still trying to decide if im going to use this engine to swap out my tired old L03...anyways, its got about 50,000 miles on it with 160 psi on the compression test. Is this good? What is optimal?
Old Jan 21, 2001 | 11:08 PM
87RS402's Avatar
For whatever it's worth my brand spanking new 4.3 ( or 3/4 350 ) was 145 on all 6 when I checked it after 2500 miles
Old Jan 22, 2001 | 08:45 AM
82camaro's Avatar
Car: 82 camaro SC
Is that 160 on every cylinder? A more important test would be to check all the cylinders (if you haven't) and compare.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jan 22, 2001 | 10:04 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Seems reasonable to me. If within about 10 psi between cylinders, it's probably OK.
ICON Motorsports
Old Jan 22, 2001 | 02:04 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Remember, camshafts also have a great effect on the cylinder psi. A larger cam with overlap will bleed pressure off and give a lower reading than a short duration/wide LSA cam.
All comments regarding "balance" between cylinders is correct and of a greater concern than the pressure itself.
Another useful test is leak down. That measures how well the cylinder holds the pressure.
Ghettobird52
Jul 5, 2024 11:18 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
BBSDesigns
Aug 11, 2015 07:39 PM
