putting carbs on lt1
Old Jan 19, 2004 | 06:30 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
LT1 with Al heads, putting a carb on instead of injection.
What is a reccomendation for the size carb? Should I expect to gain or lose HP?
Old Jan 19, 2004 | 10:02 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
if it basically a stock(ish) type motor id use a 650 or bigger....the tranny will determine what type or secondaray is best for you
im running a carbed LT1/4 (the only one on this board i beleive) with a 650 DP...headers dual exhaust just simple stuff...havent put a cam in it yet...
the only carbed intake for the LT1 motors is a dual plane...its supposed to support 450-500 ponies ported out, but judging by the ports i think its a bit conservative....anyway, with just an intake swap on a stock motor, it will perform very simialr to the injected version...probly flow a little less down low and a little more up top...
ill tell you how she runs once i get my timing issue handled...but from what ive "tasted" it will run very well
Old Jan 20, 2004 | 09:10 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
thanks.. believe my mind is made up. carb for a while , when i get a little braver ill swap in the injection..
what is the P/N or name or something of that intake?
thanks
Old Jan 20, 2004 | 10:35 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
http://www.gmgoodwrench.com/gmgoodwr...Engine%20Parts
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
sreZ28
Aug 14, 2015 07:48 PM
