power steering problem
Old Jan 22, 2001 | 10:20 AM
black305power's Avatar
i bought a new power streeing pump 2 bays ago and i still don't have power assistance in steering the book said that i have air in the gearbox and to bleed it i did what it said and still no assistance i need to know of any other possable way to help get the air out if there is any and if not what else could be wrong that i could check . oh i also checked the lines and they are all functioning thanks for the help
Old Jan 22, 2001 | 11:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
To bleed it, you fill the pump with fluid, and turn the wheel all the way to one side; that will probably drain the pump; fill it back up; turn it all the way to the other side, which will probably drain it again; keep doing that until the reservior level doesn't go down any more. That will expel all the air from the system, but it may take a while since every time you let the reservoir run dry, the pump pumps more air into the gear, so the fluid turns to foam, and you may have to wait in between fillings to let all the air rise to the top. Is that what you did?
If it is, then your PS gear is bad.
ICON Motorsports
Old Jan 22, 2001 | 07:11 PM
Vader's Avatar
BP,
RB has the solution, bt it's a little easier (and there's a little less foam) if the front wheels are raised.
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
