Plenum Removal
Old Jan 22, 2001 | 11:22 PM
Dan91Z's Avatar
Plenum Removal
I finaly started changing my fuel pressure regulator and have to remove the plenum.. I took out all the bolts from runner to plenum on both sides, unhooked all the hoses i could find, unhooked sensors, and took the throttle body off.. It seems like there is something still connected though cause it don't want to come off. Is there anything on the underside of it (besides the little wire torwards the back that unplugs) that needs to be disconnected?
the plenum does move slightly with very little force. any ideas anybody?
My `91 Z28 Convertible
Old Jan 23, 2001 | 12:03 AM
Guest
Guest
Posts: n/a
Well if you have all the bolts from the runners out (theres 8, 4 each side) then it should come off. Some cars the plenum will bind badly and you have to loosen the lower runner bolts on one side to get it out. The hose barb from the brake booster at the driver side rear of the plenum will also snag on the runner, so see if thats whats holding it up. You dont have to take the barb off, just move the plenum so it doesnt hit the runner.
Old Jan 23, 2001 | 02:18 AM
Dan87IROC-Z's Avatar
Mine stuck to the runners even after everything was off. Get a soft chisel and go inbetween the plenum and runners and just separate it. Then just pull and wiggle the plenum off!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.6:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Old Jan 23, 2001 | 03:08 AM
Dan91Z's Avatar
finaly got it off.. it was stuck on the little pin thing that holds the gaskets on.. thanks for the help!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Nick McCardle
Sep 10, 2015 08:36 PM
