Best Dist. Cap And Rotor
Old Jan 20, 2004 | 10:32 PM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Whats the best cap and rotor for a stock delco dist.?
Old Jan 21, 2004 | 04:58 AM
ede's Avatar
ede
best for what?
Old Jan 21, 2004 | 09:36 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: Best Dist. Cap And Rotor
Get one that has brass inserts for terminals. Many just use aluminum but that is not a good conductor.
The name on the box isn't important.
Old Jan 21, 2004 | 10:02 AM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
Since you're running a TPI motor, I'm guessing you have the smaller distributor cap. Auto Zone sells one under the name Conrad (should be a gold box) that has the brass connectors in it.
Best to tell the parts guy you want one with brass terminals. Any good person behind the counter should know what to look for. They are not that much more expensive, and are make of a better plastic as well.
Old Jan 21, 2004 | 11:51 AM
Morley's Avatar
Says he has an '86, so large cap, coil in cap. that is unless he has swapped it out.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
tyeo098
Nov 30, 2015 06:27 PM
BLK87Z
Sep 18, 2015 11:29 PM
m00n420
Sep 11, 2015 02:39 PM
