Is the carbon canister vacuum solenoid important?
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
The TPI system I recently installed had all emissions removed, (EGR and carbon canister solenoid) and they were removed from the ECM programming also.
Since I'm finding the EGR may be part of my detonation problem, I'm wondering if the carbon canister solenoid is important in any way to engine operation?
I know its main function is to burn off any gas fumes/pollutants from the fuel tank, but any bad effects by removing it from operation?
I do have it hooked up to a vacuum line now, just no solenoid to be controlled by the ECM.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, highly modded
95 Trans Am Conv.- LT1
Rob
Car: 88 Firebird WS6
Yanked mine and never had a problem. For extra insurance against tank "suck" Plug the line coming from the tank and use a vented cap (Some already have these for some reason... Found one in the junkyard)
I wouldn't recommend leaving the line waivin' around under the car open. Just pinch the steel line w/ vice grips and weld it (Just kiddin') or properly plug it at the tank for neater apperance. Lot of hoses and wires/relays you can get rid of from getting rid of smog, a/c, A.I.R. I can actually see my motor now!!
Pac J
May 17, 2020 10:44 AM
HoosierinWA
Oct 7, 2015 10:15 AM
