the big project 383 will begin very soon...need help on parts
Old Jan 22, 2004 | 08:59 PM
ChevyCamaro4lif's Avatar
application: 91 Z28 350 TPI auto (T56 going in within the next month or so)
i am most likely buying a base 383 stroker motor to start everything off with or if i can find an already bored .030 350 block w/ 4 bolt mains ill go from there.
plan: to run 20 PSI from Procharger kit
from here i will need anyones help as to what will be the best parts and if they will all work in order together:
1. TrickFlow Kenny Duttweiler sig heads w/ 72 cc chambers 195cc intake?
or
2. Dart Pro1 230 cc intake 72 cc chambers?
3. ESP H-beam rods
4. ESP forged crank 6.0 rod journal
5. JE HD Pistons inverted dome
6. Comp Cams Nitrous Cam (good for forced induction engines)
thats about it for the main components
now, for the best match to support forced induction and provide most power, which should i choose?
Stealth Ram
Mini Ram II
Super Ram
if its a close call between any of these, i would like to retain my strut tower brace and i know the HSR is too tall for those so...is the Mini ram lower?the super ram? but if i am going to get a big power difference w/ the HSR i will get rid or the brace.
project begins spring '04 so until then and maybe during, i will be trying to get as much info as i can on building up this 383.
Old Jan 22, 2004 | 09:14 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, I think that if you are running 20psi boost, I doubt that the intake is going to make a difference. So go with the SuperRam with some porting and you can still use a strut tower brace.
Qualifier: I have no experience running a SC.
BTW: I would recommend a splayed 4 bolt block for sure with 20psi boost.
Also, choose an appropriate fuel injector for 20psi boost.
Old Jan 22, 2004 | 10:05 PM
87350IROC's Avatar
Car: 87' IROC
Thats a lot of boost dude. What are the specs on the cam. What is you goal compression ratio?
Old Jan 25, 2004 | 04:49 PM
does anyone know if this block will work with all my L98 OEM accessories ( oil pump, water pump, etc..)?this is a Motown race block and if i decide to get it i am bringing it to a prof engine builder to bore & stroke it get it all ready for assembly.
955-084110
3.990'' Bore w/350 Main Bearings - Race Block
TECHNICAL SPECIFICATIONS
Material: High density cast iron
Deck height: 9.025'' (standard Chevrolet)
Deck thickness: .600'' minimum
Cam bearings: Standard Chevrolet small block set
Main bearings: Standard Chevrolet (350 style)
Camshaft location: Stock
Lifter bores: Indexed (stock .875'' bore)
Bore: 3.990 (hone to 4.000'')
Maximum bore: 4.200''
Cylinder wall thickness: (.250'' @ 4.200'' bore)
Water jackets: Expanded for better cooling
Lubrication: Priority main oiling system
Oil system features: Integral boss for front feed, boss for rear scavenge rear main cap has provisions for wet sump pump
Filtration: Integral mount for spin -on filter
Oil pan rails: Solid (stock width) can be clearanced for strokers
Crank clearance: 3.875'' stroke (I-beam steel rods)
Main caps: Nodular iron 4-bolt (1/2'') with dowels
Fuel pump:OEM mount
Starter: OEM mount
Motor mounts: Dual (front and side)
Cylinder head holes: Blind tapped to prevent leaks
Weight: Approximately 190 lbs.
Old Jan 26, 2004 | 11:27 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
WOW, sounds like you may need wings!! with that much boost you may want to use the miniram, it is alot easier to work around, alot easier to install, and sit's plenty low for a strut tower brace.
Cleotiz
Jan 6, 2018 08:56 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
