Where to get new MAF connector?
Old Jan 23, 2001 | 03:08 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
I need to get a new one. Anyone know where to locate them? Or, does GM actually sell these without buying a whole dang harness. I went nuts trying to get connectors for my T56 from them.
Mark Lock
- 86 IROC-Z - SuperRammed 383/T56
- -= IROC Online =- - The site dedicated to the IROC-Z
Old Jan 23, 2001 | 03:45 PM
Guest
Guest
Posts: n/a
You can get them from a decent parts store. Standard Ignition is a parts company that sells them, and I think Dorman/Motormite has them as well. More than likely wherever you get it they will have to order it, and IIRC the connector is about 10-15 bucks.
Old Jan 23, 2001 | 08:48 PM
Pat Hall's Avatar
Ummmmm, you might want to grab a pair of dykes and try your local junkyard. Almost every GM car with a MAF sensor used the same style plug. They'll probably let you have the connector for nothing. If they're really petty, you may have to give em a buck for it. I bought a used TPI harness that needed a lot of connectors replaced, and I got every one I needed from the junkyard for like a couple of bucks.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Jan 23, 2001 | 09:46 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Pep Boys has them in the help section, just ask. Not a special order part.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Jan 23, 2001 | 10:54 PM
Vader's Avatar
Originally posted by Pat Hall:
Ummmmm, you might want to grab a pair of dykes and try your local junkyard...
Pat,
I understand the junkyard thing, but I'd rather go by myself, thanks anyway. I might take some diagonal cutters, though...
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 24, 2001 | 02:56 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I got mine from AutoZone. They have most of the replacement sensor connectors you'll need hanging in the electrical area.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Jan 24, 2001 | 03:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hm, this question sounds familiar...
https://www.thirdgen.org/messgboard/...ML/002705.html
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
BumpaD82
Feb 26, 2016 02:57 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
Nick McCardle
Sep 10, 2015 08:36 PM
