Fuel pump questions?
Old Jan 24, 2004 | 01:27 AM
CogsRS's Avatar
Car: 87 Monte Carlo SS
Transmission: 200 4R
Who has replaced their fuel pump in their garage? I need some help, actually I just need someone to tell me exactly how to do it. Also, can I swap my TBI pump to a TPI? Would there be any benefit if it is possible? I plan on swapping to TPI within the next year, that's why I ask. Thanks.
Old Jan 24, 2004 | 08:01 AM
ede's Avatar
ede
there is a big differance in tbi and tpi pumps, in price and output. you need the pump to match your fuel delivery system. the pump is located in the fuel tank. drop the tank and access is through the top of the tank, where all the lines are. you'll need to lower the rear, but not remove and remove any exhause that's in the way. it's not near as hard to do as it sounds.
Old Jan 24, 2004 | 10:11 AM
CogsRS's Avatar
I need to replace the rear anyway...so I might as well take it off. What else to I need to remove or move, other than exhaust?
Old Jan 24, 2004 | 10:52 AM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
to make your life easy, i'd drain the tank.... its easy n wont take u long
the lines (there'll be 3 of them i'm sure) are connected, once u unhook the straps and disconnect them lines (they are easy) you'll have the tank out and your set...
its nice to have someone else thre for safety if you dont drain the tank... sucky to get the tank to fall on you n pour gas all over you..
hate smelling like gas
Old Jan 24, 2004 | 09:32 PM
84and85bird's Avatar
Car: 84 Firebird & 85 Firebird
Engine: 2.8 V6 : 2.8 V6
Transmission: 700R4 : 700R4
Remember to remove the fuel filler door and the plastic around the fuel filler neck before you unstrap the fuel tank.
I had a heck of a time getting my fuel tank to wiggle out from under the car. I used a hammer and a block of wood to beat on the filler neck to get the tank out. It should come out without having to do that though.
Most of the job is pretty strait forward. The only thing that can be hard is getting the tank angled just right to get it out (and back in).
A 20 inch breaker bar does wonders at getting some of those suspension bolts to loosen.
Did you check your fuel pressure with a fuel pressure guage? It would really stink to go through all the work of dropping the tank and not even needing to.
Old Jan 24, 2004 | 11:44 PM
CogsRS's Avatar
There is deffinately NO fuel getting to the motor. The car cranks but will not catch. I am 99.9% positive it is the fuel pump, so Im not worried about that really. Its ok that I have to do it anyway because I want to put an access door in for when I convert to TPI and I want to replace the rear and exhaust anyway.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
