Timing gear drive
Old Jan 26, 2004 | 05:04 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Timing gear drive
I saw in a post that gear to gear timing robs horsepower. Is this true? If so, why?
Old Jan 26, 2004 | 05:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It takes more power to turn meshing gears than a chain does.
However, racers use gear drives because of more precise control of cam timing.
Old Jan 26, 2004 | 05:59 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Chain gear drive aren't the best for street cars because it can give off false knock and your car will suffer from timing retard.
Old Jan 27, 2004 | 05:08 AM
ede's Avatar
ede
if you're after precise timing control use a belt drive plus there's no noise to interfer with the ecm
Old Jan 27, 2004 | 12:30 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Not to mention that no one to my knowledge makes gear drive for TPI cars. I checked around and contacted a few gear drive manufactuers and they said they dont make them for the newer cams that have a smaller nose, rather than the larger nose of the old cams, or some crap like that.
Old Jan 27, 2004 | 08:43 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Its on a 383.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
novaderrik
Aug 10, 2015 12:44 PM
